All the names have changed
Home Forums Puzzles All the names have changed
  • #5557
    vincent
    After a update in the app manager, there is a update inside the app manager (a second). It’s an arrow in form circle… but after my puzzle as a mystake, all the names are red(missing) and there rename by “with a dot”in the list
    Why it’s a happen ?
    #5572
    Why it’s a happen ?
    We added a support of dots in the object, but in previews versions it’s just was discarded from each name. Only way to fix this is to choose in each puzzle block the correct names again and save. But a good news that now you can use unicod charachters in names for the object.
    #5575
    vincent
    if i understand well The objet’s name change. I have to change after doing my puzzle. I have all my puzzle to redo. While he was working properly.
    #5576
    The object usually was changed before this versin, th engine always converted some of the specific charachter to empty or changed it with “_” sign or something else, now you will always get the same name in the puzzles like it was in blender. You need just to check all puzzles node with red highlighted names of the object and select a new names that now are simmilar to Blender objct’s names. And save puzzles again and all be ok.
    #5581
    vincent
    Ok thank… A other thing : How to use a old puzzle since backup, just drop the file xml in first place.
    #5582
    You mean how to use backup files to restore the previews version of the logic? Yes, just put the file in the main project folder, delete the old one and rename the backup file to ‘visul_logic.xml’ without a data numbers. Then open puzzle editor and save them once.
