Home › Forums › Bug Reports and Feature Requests › After update to 4.0: Puzzles have no effect
- This topic has 26 replies, 8 voices, and was last updated 2 years, 5 months ago by
Ivan Lyubovnikov.
2022-07-14 at 11:15 pm #54147
David Yanez
CustomerThe same has happened to me, please help!
After updating to version 4.0.1 only the init and main tabs appeard, but my custom puzzle tabs disappeared. Also, I am not able to link scene objects anymore. I.E., when I choose a selector (object, group, light, etc.), there is no dropdown options from the maya scene.
And I also find weird that when running the index.html file, everything works as before, but I cant see nor edit in the new puzzles. How can I restore the visual logic files from the prior version 4.0 pre3? I´ve tried re installing this previous version but I still get the mentioned errors.
I’ll appreciate the feedback.
You must be logged in to view attached files.2022-07-14 at 11:51 pm #54149kdv
ParticipantAnd I also find weird that when running the index.html file, everything works as before
It’s not strange, old
visual_logic.js
will work with no problem if not changed with this new buggy puzzle editor. Looks like the new puzzle editor in some cases can’t readvisual_logic.xml
correctly…Can you show your
visual_logic.xml
?Puzzles and JS coding. Fast and expensive.
2022-07-15 at 1:07 am #54150David Yanez
CustomerThank you kdv77kdv,
Here is the visual_logic.xml file created on prior verge3d 4.0 pre3 version.
2022-07-15 at 1:10 am #54151kdv
Participantpack it into .zip before attaching…
2022-07-15 at 1:45 am #54152David Yanez
CustomerSorry about that. Here is the zip version
2022-07-15 at 2:05 am #54154kdv
ParticipantHere’s what the browser console shows. I can see your custom puzzle tabs, but they are empty…
It’s strange, but your .xml really have the shadow block that is located as a top-level block )))
Somehow the shadow block
1024
was saved as a top-level block separately
Try the attached file. It should work fine now…
2022-07-15 at 3:13 am #54160David Yanez
CustomerYour awesome!
How did you fix it? I’m able to see my custom tabs again, thank you so much!
One question though, I had a puzzles plugin installed in the 4.0 pre 3 version but with the updated 4.0.1 version it doesn’t show.
Might the plugin need an update as well? I just copied the plugin folder to the “verge3dm_maya/puzzles/plugins” location where the E-Commerce and SCORM are. In case you know I’ll appreciate the guidence.
Again thanks!
You must be logged in to view attached files.2022-07-15 at 3:35 am #54162kdv
ParticipantI don’t know. Maybe it’s not compatible now. Attach .zip with this plugin to see it closer…
How did you fix it?
Just removed
shadow
top-level block shown on the screenshot above ))) it’s not supposed to be there…Puzzles and JS coding. Fast and expensive.
2022-07-15 at 3:07 pm #54171David Yanez
CustomerThanks kdv77kdv for all the help.
This is the plugin.
2022-07-15 at 8:19 pm #54179kdv
ParticipantInside
Zjbcool-color-v1.0
folder you’ll findZjbcool-color
. That’s where the plugin is located. CopyZjbcool-color
toverge3dm_maya/puzzles/plugins
2022-07-15 at 11:46 pm #54180David Yanez
CustomerOf course! I slipped there. Thanks again for all the help kdv77kdv, you rock!
2022-11-03 at 3:08 pm #57064Ivan Lyubovnikov
StaffIt’s strange, but your .xml really have the shadow block that is located as a top-level block )))
Regarding the shadow block issue: this is a bug that will be fixed in the next verge3d update. More info here: https://www.soft8soft.com/topic/puzzles-are-gone/#post-57062
