Addressing html transitions for PopUp Windows
Home Forums General Questions Addressing html transitions for PopUp Windows
  • #63626
    vjecht169
    Hello,
    it’s me again :)
    I have been working with Webflow in the meantime and also managed to link Verge3D and Webflow.
    The goal is that I click on a 3D object and a window pops up that has a transition animation (scale, opacity etc).
    Now I have a concrete problem that I do not know how to design transitions when opening windows within puzzles.
    Attached is an attempt of a puzzle where I tried to copy Html from Webflow, but it didn’t work.
    Here is the example of how I want it and what currently works :)
    https://v3d.net/jcs
    Thanks for help :)
    • This topic was modified 1 year, 10 months ago by vjecht169.
    #63643
    Hi vjecht169,
    Here is one of possible ways how to implement CSS animation with Verge3D Puzzles:
    #63652
    vjecht169
    Hey,
    thank you for your reply…
    I tried to adapt your puzzle, but unfortunately it didn’t work …
    Attached you´ll find my puzzle and a screenshot of the html (with F12)
    Here you see, that Section02 is grey…
    What am I doing wrong? :cry:
    Best :bye:
    #63655
    you’re making mistakes
    remove spaces between scale3d and arguments. And in your case Section02 is not a class name. Use .section-2 instead of .Section02 when creating your CSS rule.
    And you should use this puzzle before starting the animation to show the window
    #63712
    vjecht169
    Hello,
    I have implemented your suggestions and everything went wonderfully so far.
    Thanks again. :good:
    But now I have the problem that when opening the window via the green area the first time everything works wonderfully. The window remains until I click on X.
    The 2nd time I click, the window opens, but does not remain and closes again immediately ?
    I have tried many things – also in Webflow – but unfortunately have not come to a result?
    https://v3d.net/jcs
    I hope you can help me -again- ;-)
    • This reply was modified 1 year, 10 months ago by vjecht169.
    #63714
    The window doesn’t disappear, it just scales to 0 when the animation ends.
    When you click for the first time the default scale is 1. When the animation ends the scale is set to the default value and you see the window as expected.
    When you click X the default scale is set to 0 (but the window is still visible).
    As a result at the end of the second animation the scale is set to 0 and the window “disappears”.
    You need to set the scale back to 1 and hide the window after clicking X.
    #63720
    vjecht169
    Wow it works…
    thanks a lot – you´re great :good:
    #63886
    tlaloco
    How can I display a menu when I press a volume button like this?
    • This reply was modified 1 year, 10 months ago by tlaloco.
