Additional Reflection Map
Home Forums Graphics / 3ds Max Additional Reflection Map
  • #48122
    jamjam
    Hey,
    what would be the best approach to add reflections to a material if the environment slot is already used?
    I have a building which is lit by an HDRI in the environment slot.
    I would like to add a reflection map with some clouds to the windows.
    Is this possible on a material or object basis?
    Thanks
    #48171
    You can try to place thhe objet that you want to be reflected in the scene and bake cubemap lightprobe, then hide the object.
    #48173
    jamjam
    Thanks for the tip.
    Not sure if I overlooked something, but I couldn´t find any information on how to bake lightprobes in the 3ds max.
    Any help is much appreciated.
    #48174
    please check out this tutorial
    see also this doc page:
    https://www.soft8soft.com/docs/manual/en/max/Lighting-and-Rendering.html#light_probes
