Adding Java into puzzles/ extracting code from visual_logic.js
Home Forums Programming Adding Java into puzzles/ extracting code from visual_logic.js
  • #79833
    boing
    What a great software Verge3d is!
    I have this simple file
    https://jayceee.com/wp/CLIENTS/AnimSoundNav/AnimSoundNav.html
    including a subtitle generator (a div block in AnimSoundNav.html and code in visual_logic.js from line 418). Whenever I save the puzzles Verge overwrites the visual_logic.js file though.
    Is there a way to extract the code to an exec script file that runs in puzzles or a text file that I could just add into the visual_logic.js after I saved the puzzles?
    I am only starting with Java and am struggling with extracting the code…..
    Any tips/help much appreciated
    Thank you
    C.
    File here: https://jayceee.com/wp/CLIENTS/AnimSoundNav.zip
    #79840
    Here.
    #79876
    boing
    @kdv THANK YOU SO MUCH!
    Well done you.
    In case anyone needs a subtitle/voiceover/anim file, find the verge project (Blender) here:
    https://jayceee.com/wp/CLIENTS/AnimSoundNav_02.zip
    Courtesy of @kdv!
    :yahoo:
    • This reply was modified 2 months, 1 week ago by boing.
