Adding class to existing POI…?
Home › Forums › Puzzles › Adding class to existing POI…?
  • #23060
    David Duperron
    Hi!
    I was wondering if there was a possibility to add a custom class to a pre-existing annotation (POI), either on top of the default “v3D-annotation” class, or in addition to it…? This is to be able to have several styles of annotations.
    I tried using the “set attribute” puzzle, with the “classname” attribute to one existing PI, but without any success for now…
    Is it possible? Or is there some other way to do it, before to switch to custom bits of html that I would bind to my 3D objects…?
    Thanks for the help!
    Cheers
    David
    #23062
    David Duperron
    EDIT:
    I found a solution with a CSS selector that looks for a specific substring inside the “id”, which works perfectly…
    .v3d-annotation[id*="-MM-"] {
        background-color: blue;
    will style all my annotations with “-MM-” in the id name with a blue background. I did not need anything more! :)
    #23066
    Glad you found a solution! :good:
