- This topic has 9 replies, 4 voices, and was last updated 2 years, 5 months ago by
visualizer.
2022-10-10 at 1:14 pm #56540
NaxosCG
CustomerHello,
Can you add the “tabindex” property in the “set prop” puzzle list for html, please ?
I need it for some stuff.
Thank you."1+1=3... for large values of 1"
2022-10-11 at 7:10 pm #56592Alexander Kovelenov
Staff2022-10-12 at 6:45 am #56608NaxosCG
CustomerHi,
added this task to our priority TODO list.Many thanks, Alexander.
The idea behind this need, is to manage the full html menu directly within the Verge3D applet, using a csv file.
So, regardless of what (here) billards table is appended to the scene / loaded, the html menu will be changed with available vignettes that fits this particular billard.
And, it seams that my JQuery menu i’m using needs “tabindex”.Kind Kdv77kdv user / dev talked about some script code to add, but it does not work, dunno why.
2022-10-12 at 6:46 am #56609NaxosCG
CustomerOf course, this could be solve with a nice 2D HUD full system within Verge3D, with new series of puzzles, so no more html needed
2022-10-12 at 6:59 am #56610kdv
Participanttalked about some script code to add, but it does not work, dunno why.
It works, but only after the tabs have been created.
You menu script also assigns
tabIndex
for tabs:0
for the active tab and-1
for the inactive ones. So you need to make some changes injquery-ui.js
too. Find two stringstabIndex: 0
and deactivate them.Puzzles and JS coding. Fast and expensive.
2022-10-12 at 7:05 am #56612NaxosCG
CustomerSo i should add this script in my “neutral” html’s head ?
I can try, again sorry for my so low level in code.
2022-10-12 at 3:44 pm #56618kdv
ParticipantYou already have the script in the html’s head
<script>$(document).ready(function() {$("img.min").click(function(){$("img.viewer#"+$(this).attr("value")).attr("src",$(this).attr("title"));});$("#TabbedPanels1").tabs();});</script>
Replace it with this one
<script> $(document).ready(function() { $("#TabbedPanels1").tabs(); const allTabs = document.querySelectorAll('.ui-tabs-anchor'); for (let i = 0; i < allTabs.length; i++) { allTabs.tabIndex = i + 10; } }); </script>
And use
jquery-ui.js
attachedAttachments:
You must be logged in to view attached files.Puzzles and JS coding. Fast and expensive.
2022-10-25 at 12:14 pm #56861Alexander Kovelenov
StaffHi, we just supported tabindex in Verge3D 4.2 pre2
2022-10-25 at 4:36 pm #56863NaxosCG
CustomerHi, we just supported tabindex in Verge3D 4.2 pre2
Many thanks, Alexander !
2022-11-15 at 5:13 pm #57353visualizer
CustomerHi
This is interesting !I dont understand much advanced. Share any ref. screenshots if possible.
