Add static background image on scene
Home Forums Graphics / Blender Add static background image on scene
  • #21226
    lamthanhle
    Hello Everybody,
    How can I set a static background image (even rotate your main camera, the background doesn’t change) and view it with verge3d ?
    Thanks
    #21227
    you can parent a textured plane to the camera
    #21288
    lamthanhle
    Hi Yuri,
    Parent work only in blender but export not work.
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:4af844d8a4/applications/bottle/bottle.html
    #21302
    Can you share you blend file? Or better just set background as html element and set Transparent in Init tab of the Puzzles.
    #21354
    lamthanhle
    Hi Yuri,
    This my blend file, pls check it. I think resolve it in blender/v3d setting is better than using HTML.
    Thanks
    Btw: v3d 2.17-pre1 has somthing wrong with blender 2.81. You can check it by open load_unload.blend and export/sneakpeak.
    #21379
    our bad! will fix that asap. thanks!
    #21380
    there is no background plane in your file, or I’m missing something?
