Add IE11 compatibility to an existing project
Home › Forums › General Questions › Add IE11 compatibility to an existing project
  • #32932
    jamjam
    Hey,
    how can I add IE11 compatibility to an existing project?
    From the FAQ I only found, how to add it to a new project
    “Enable IE 11 compatibility module in the app creation panel.”
    Thanks!
    #32933
    yes it is possible. You can copy the file ie_compat.js from the build folder to your application folder, and then link it in your_app.html file as follows:
    <script src="ie_compat.js"></script>
    This line must be added above the existing line that links v3d.js, that is, in the following order:
      <script src="v3d.js"></script>
