Accessing the movement data generated by drags
Home Forums General Questions Accessing the movement data generated by drags
  • #22607
    rainman
    Hello, I would like to be able to move an object’s UV cords around using dragging. I, however, cannot seem to find how to access the values that the “When Dragged” puzzle generates. One alternative I just thought of would be to move an invisible object around with drag and then use that object’s position to change the UVs. Is there a way to change a value directly using the when dragged puzzle. (i am using Blender and moving the UVs through a value input node)
    #22613
    this can be done with JavaScript I think – check out the code generated by drag puzzles in your_app/visual_logic.js file
    Yes, I think this can be implemented with Puzzles – you should add Value nodes to your shader in order to transform the UV coordinates. Then use the get transform and set value puzzles to map your UV to the object world coordinates.
    https://www.soft8soft.com/docs/manual/en/puzzles/Objects.html#get_transform
    https://www.soft8soft.com/docs/manual/en/puzzles/Materials.html#materials_set_value
