Access to render function, Composer Passes
Home Forums General Questions Access to render function, Composer Passes
  • #13699
    mikeparisi
    Hello again,
    I would like to add composer passes to the renderer. Also, I would like to call different functions before the renderer.render method is called. Do I have access to this?
    Thank you,
    Michael
    #13707
    The render method can be accessed via the app variable in your application js file.
    #13722
    mikeparisi
    Hey Yuri thanks for your reply. I assume that verge has its own requestanimframe function in which app.renderer.render is called. Is there a hook available to call functions before this render call?
    #13772
    Yes, you can add your own functions to the loop using:
    app.renderCallbacks.push(your_function);
    #13931
    mikeparisi
    great, is there documentation for this?
    is there a windowresize callback also?
    Thank you
    #13963
    here you go https://www.soft8soft.com/docs/api/en/extras/App.html
    The callback is called .onResize()
