About the transparent material Settings in blender!
Home Forums Graphics / Blender About the transparent material Settings in blender!
  • #17582
    Everybody is good!
    I have two objects with transparent properties, but the rendering in verge3d doesn’t look right! :cry: :cry:
    #17593
    And HDR doesn’t seem right!So the lighting is very different from blender!Because the lighting in verge3d is not what this image should be, and the eevee rendering in blender is correct!
    #17598
    can you attache an example file?
    #17620
    Hi,Mikhail!
    I have uploaded the file to the attachment, thank you for your help! ;-) ;-)
    #20441
    Hi,Mikhail!
    You used “Is Transmission Ray” as input for Mix Shader nodes that not supported. Use instead of simple value or Fresnel mask.
