Home › Forums › General Questions › About the deformation modifier in 3dmax!
- This topic has 19 replies, 4 voices, and was last updated 4 years, 8 months ago by
web.
2019-07-20 at 9:30 am #17135
Yearning for the future
CustomerI am sorry, because this may be a novice problem!When I try to use verge3d to produce works, I need to use some deformation modifiers in 3dsmax to complete some animation transformation effects, but verge3d does not seem to support much, I would like to ask, which modifiers can verge3d support?How do I control them in verge3d?
2019-07-22 at 6:46 am #17157Mikhail Luzyanin
StaffOnly skin modifyer supported, may be morph modifyer will be supported in the near future.
2019-07-22 at 6:54 am #17161Yearning for the future
CustomerHi, thanks for your help.I was aware of this problem before, so I deliberately used blender to create the effects I needed.But I still can’t use the shape key to make the animation I need.What should I do?I select the export modifier and other check boxes!
2019-07-22 at 7:10 am #17162Mikhail Luzyanin
StaffHi, thanks for your help.I was aware of this problem before, so I deliberately used blender to create the effects I needed.But I still can’t use the shape key to make the animation I need.What should I do?I select the export modifier and other check boxes!
Can you share your blend file?
2019-07-22 at 7:14 am #17163Yearning for the future
CustomerI have uploaded the file to the attachment. I just started using this software this morning, so I may have made some stupid questions. I hope you don’t mind!Thank you for your help!
2019-07-22 at 7:16 am #17164Mikhail Luzyanin
StaffSeems like it’s to big to be attached? can you upload it somewhere and share the link?
2019-07-22 at 7:19 am #17165Yearning for the future
CustomerNot very important, I have uploaded the attachment when I replied, didn’t you receive it? :)
2019-07-22 at 7:52 am #17168Mikhail Luzyanin
Staffnope. I think it too big for the forum to be attached.
2019-07-22 at 8:13 am #17169Yearning for the future
CustomerOh!This……Sorry, I’m a Chinese user, I don’t know where to upload the file, so you can receive my file…
I think I can describe my animation effect: I add shape key to object B as the binding object of mesh deformation of object A, and change the shape of object A by changing the shape of object B;This process is correct in blender!2019-07-22 at 8:19 am #17170Mikhail Luzyanin
StaffSeems you do all right, to figure out the problem we need to see the file. May be you can simplifie it so it will weight less and you can attache it to the forum.
2019-07-22 at 8:33 am #17171Yearning for the future
CustomerAlthough I tried hard to compress the file size, I still couldn’t meet the condition limit, so I exported the FBX format, but after importing it, it seems that I need to re-add the mesh deformation modifier to object A and bind it, I’m sorry…
2019-07-22 at 8:36 am #17173Yearning for the future
CustomerI can’t see if the attachment has been uploaded here, but I’m sure the file size is ok because it’s only 451KB
2019-07-22 at 8:53 am #17174Mikhail Luzyanin
StaffI can’t see if the attachment has been uploaded here, but I’m sure the file size is ok because it’s only 451KB
Yes, still can’t get it. Can you send it to me on email ?
2019-07-22 at 9:06 am #17175Yearning for the future
CustomerHello, I have sent the document to your E-mail address.Thanks for your help!
2019-07-22 at 9:34 am #17180Mikhail Luzyanin
StaffYou made it using modifyer it will not work that way, you need to convert it to shapekeys before and animate, or export to mdd file and import it again to get shapekeys set to your object. Here’s your example with correction.
