1ms black frame when loading video
Home Forums General Questions 1ms black frame when loading video
  • #53409
    acidarts
    hello,
    I’m trying to make videos loaded on start (videos are muted), but once I start the page, there’s a 1ms (very quick) black frame on the video and then it starts. The object has the texture of the first frame of the video, and I thought it would workaround the issue but it still behaving.
    I took a look at your Video Texture demo and same thing is happening when you click on the screen, there’s a very quick black frame.
    Is there a way to workaround this? Thanks.
    #53412
    I think this is because video needs to be loaded which takes some short period of time. A possible workaround can be to use some overlapping object that can be hidden after the video is loaded.
    #53413
    acidarts
    Yeah, that makes sense, thank you.
    I’ve got another workaround, but I’ll need to test on different devices to see if it’s working, but freezing the screen 1 sec only after the preloader seems to let the video load and then the scene appears.
