16 bit texture files
Home Forums Graphics / Blender 16 bit texture files
  • #32271
    hi, im trying to avoid banding in textures, and i tried 16 bit png files, in blender it looks perfect but in verge i get horrible banding in areas with color grading, is 16 bit png supported? if not, if not, is there a format that is?
    -Michael
    #32275
    16-bit textures are not supported. You might try enabling Dithering in Verge3D settings for your material and see if it helps.
    #32276
    ok, i will try to grain things up! silly question maybe, but is this a feature that could be added later on? or is there a technical challenge?
    thanks for clerifying anyway Yuri!
    #32278
    You’re welcome!
    As of 16-bit textures, you can still try using the .hdr format, may be it’ll work out.
